Rich Posted December 22, 2004 Posted December 22, 2004 So to sum up LJD are a waste of space? 35259[/snapback] Yep, I wouldn't touch them with yours
ian.cant Posted December 22, 2004 Posted December 22, 2004 Yep, I wouldn't touch them with yours That would be because you only have 8 fingers and 2 thumbs, frankly that aint enough to get a good grip of me!
Guest eddiefast Posted December 22, 2004 Posted December 22, 2004 over the moon with this software .very easy to set up. remote view and play are very easy to use once again thanks B) eddie
Guest Peter James Posted December 22, 2004 Posted December 22, 2004 I think the Leviathan range is a good cheap alternate to pro stuff, but I have never used the really cheap DVR's from LJD. Pete
Guest Adrian Posted January 13, 2005 Posted January 13, 2005 over the moon with this software .very easy to set up. remote view and play are very easy to use once again thanks B) eddie 35276[/snapback] Can you give us a little report on the system you are using it on, and how good the quality of the image is on the remote side of it. As I'm specking this model for a number of quotes I have done. Adrian B)
Guest eddiefast Posted January 14, 2005 Posted January 14, 2005 Can you give us a little report on the system you are using it on, and how good the quality of the image is on the remote side of it.As I'm specking this model for a number of quotes I have done. Adrian B) 37071[/snapback] hello adrian i use this system at home and fined it to be ok but i would not dream of putting this into a work place as it just doesnt cut the grade. as for remote monitoring its basic .if your customer wants a budget system this is it a budget system but dont exspect other jobs from it . i am not a cctv snob just know sh!t from sh!te. pm me if you would like to remote access my system and i will give you detail on my account hope this helps eddie
Guest eddiefast Posted January 15, 2005 Posted January 15, 2005 this is a screen shot sorry i cannot give you access because of firewall on my router i will enail you when its sorted hope this helps eddie
Guest Adrian Posted January 15, 2005 Posted January 15, 2005 B) Hi could you give details of the type of camera and lensess used and is this the remote access view or direct off the the dvr. The size of the hard drive how its set up Ie motion dectection etc... If you don't want to post that info on here please e-mail me Many thanks Adrian B)
Brian c Posted January 16, 2005 Posted January 16, 2005 Seems pretty good quality that. What model do you have? If you don't know......ask.
