bjj Posted November 11, 2023 Posted November 11, 2023 (edited) Hi I am looking to replace 7 analogue cams with ip poe cams but wanted to keep my Samsung DVR which is a SRD 1673D some DVRS can switch from analogue to ip (I have read ) but don't think this one can, does anyone know is there a piece of kit that can convert the new ip cams to use on this DVR and would the picture quality be affected. many thanks. All cables are run in cat5 at the moment. bjj Edited November 11, 2023 by bjj Quote
sixwheeledbeast Posted November 11, 2023 Posted November 11, 2023 It will only record in analogue resolutions even if converted, not recommended. Some machines are "hybrid" so you map IP's to the channels, this usually requires PoE elsewhere and detecting cams from the WAN. Just replace the lot with new Samsung. Seems a shame to get rid of a decent DVR but if 960H isn't good enough now (new cams?), you need to start again. 1 Quote
MrHappy Posted November 11, 2023 Posted November 11, 2023 On 11/11/2023 at 09:21, bjj said: Samsung DVR which is a SRD 1673D Expand the internet says its does upto D1 / 960H ? 1 Quote Mr Veritas God
al-yeti Posted November 11, 2023 Posted November 11, 2023 On 11/11/2023 at 09:21, bjj said: Hi I am looking to replace 7 analogue cams with ip poe cams but wanted to keep my Samsung DVR which is a SRD 1673D some DVRS can switch from analogue to ip (I have read ) but don't think this one can, does anyone know is there a piece of kit that can convert the new ip cams to use on this DVR and would the picture quality be affected. many thanks. All cables are run in cat5 at the moment. bjj Expand Waste of time , seriously, those recorders you can't even give away now, even swann has overtaken it So you will be like trying to fit ip 720p or something like that 1 Quote
bjj Posted November 11, 2023 Author Posted November 11, 2023 Looks like the chequebook lads thanks for all your replies. 1 Quote
sixwheeledbeast Posted November 11, 2023 Posted November 11, 2023 Maybe consider the spec, I know it seems easy to throw stuff where it is now. As much as you may wish to DIY, correct placement and design could see significant savings with better and more usable footage. 1 Quote
james.wilson Posted November 12, 2023 Posted November 12, 2023 I also read on ha forums and see in YouTube things like the best camera review. They rarely are 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
