bjj Posted February 1, 2024 Posted February 1, 2024 Hi can anyone answer this one, I have two outside lights front and rear of the house connected to cts 1011 and 1012 via relays programed log. In links 01. 1011-e/e horn. Link 02. 1012-e/e horn, in outputs *00 ent/ex horn R, Pos, all woks fine k/pad sounds when front or rear light comes on but i get the same sound from the k/pad is it possible to get a pulsing sound so I know which ilight is which. many thanks. bj Quote
james.wilson Posted February 1, 2024 Posted February 1, 2024 Not in the panel programming. You would need to add a pulse relay or use a sounder with 2 different inputs 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
bjj Posted February 1, 2024 Author Posted February 1, 2024 2 hours ago, james.wilson said: Not in the panel programming. You would need to add a pulse relay or use a sounder with 2 different inputs Thanks for your quick reply James I did think of two different types of buzzer on different outputs but there are no rios near the k/pad so will leave as is. but thanks again. Byron Quote
