mikeald Posted December 22, 2004 Posted December 22, 2004 i have asked this before, but forgot the outcome!!!! can anyone recommend a good 12volt relay which i can use to switch 2 x 500watt 240v halogen lamps from my galaxy 60 in my house? I intend for these lamps to come on in the event of an intrusion and i also want to assign a code to them as a 'link' so i can turn them on/off whenever. hope someone can help? mike Intruder & Fire Member
Guest Posted December 22, 2004 Posted December 22, 2004 I'd go with that, I usually find that at least one wholesaler in any area will have a range of relays\contactors\enclosures\starters etc...
Guest Posted December 22, 2004 Posted December 22, 2004 Yep - gardiners do them with the base too - about 7 squid all-in.
antinode Posted December 22, 2004 Posted December 22, 2004 How would you do that? Would you wire the relay contacts across the light switch, and get the panel to activate the relay in an alarm condition? Trade Member
breff Posted December 22, 2004 Posted December 22, 2004 I think you'll find that they will switch 10A ,so 2x500w will be no problem. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Posted December 22, 2004 Posted December 22, 2004 i have asked this before, but forgot the outcome!!!!can anyone recommend a good 12volt relay which i can use to switch 2 x 500watt 240v halogen lamps from my galaxy 60 in my house? I intend for these lamps to come on in the event of an intrusion and i also want to assign a code to them as a 'link' so i can turn them on/off whenever. hope someone can help? mike 35278[/snapback] prog a code as level 0 and then link it to the op...(the relay as prev posts..)
mikeald Posted December 23, 2004 Author Posted December 23, 2004 thanks guys i will look around! merry xmas to all! mike Intruder & Fire Member
