SteveDaBeard Posted February 11, 2024 Posted February 11, 2024 I'm still kicking ideas around. I want to have the intruder alarm with CCTV recorder in one building, then in another where the CCTV cameras, some PIR's and door switches. Extending the network via a wireless bridge for the CCTV cameras is easy enough, but not sure how to overcome trying to send signals back to the other building from the intruder detectors (without cables). Is there a box of tricks to convert the on/off signals from the intruder detectors via the wireless bridge and back to on/off signals for the intruder alarm? Or is there such a system out there for CCTV and intruder alarms all inside the same box using the network system? As usual, thanks in advance for any useful information Quote
sixwheeledbeast Posted February 11, 2024 Posted February 11, 2024 Either separate systems or wireless depending on distance. Quote
james.wilson Posted February 11, 2024 Posted February 11, 2024 Not directly with anything decent. I'd seperate the issues. Diy you could use texecom with it's issues that would sort your detection. Then WiFi bridge your cctv Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted February 11, 2024 Posted February 11, 2024 28 minutes ago, james.wilson said: Not directly with anything decent. I'd seperate the issues. Diy you could use texecom with it's issues that would sort your detection. Then WiFi bridge your cctv Unless he uses ha system which provides that but decent stuff might cost 40k Quote
james.wilson Posted February 12, 2024 Posted February 12, 2024 No not at all I use home assistant. It's free but I pay for it. If no one pays it fails to exist. Like cloud alarm platforms Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
SteveDaBeard Posted February 12, 2024 Author Posted February 12, 2024 12 hours ago, sixwheeledbeast said: Either separate systems or wireless depending on distance. The distance between buildings as the crow flies is 25 metres. However my concern is the building where the alarm panel will be sited has been insulated with silver foil, so acts as a Faraday cage (I've already had to move the TV antenna from the loft to the outside of the building). Quote
SteveDaBeard Posted February 12, 2024 Author Posted February 12, 2024 12 hours ago, james.wilson said: you could use texecom I've contacted Texecom and presented them with my site issues and asked if they have something suitable. Quote
al-yeti Posted February 13, 2024 Posted February 13, 2024 On 11/02/2024 at 22:47, sixwheeledbeast said: Either separate systems or wireless depending on distance. So the mesh would work? If you place the receiver in an IP box outside each building for the intruder ? Texecom? 25m Quote
sixwheeledbeast Posted February 13, 2024 Posted February 13, 2024 Can't see any issue with 25m just straight to devices. Quote
norman Posted February 13, 2024 Posted February 13, 2024 9 hours ago, sixwheeledbeast said: Can't see any issue with 25m just straight to devices. Even through the foil insulation? Quote Nothing is foolproof to a sufficiently talented fool.
