mikeald Posted December 25, 2004 Posted December 25, 2004 merry xmas all! A while ago i had a set of lovely drill bits, they were about 12 inches long and 5,6,7 and 8mm in diameter - perfect for door contacts(drilling thru wooden frames) They weren't flat bits, they were normal drill bits. I bought them at the local market for a fiver. Now however my apprentice has snapped them all - bless him! I have looked EVERYWHERE to find similar drill bits but to no avail. Does anyone know a place online that sells these sort of bits (not flat bits thou). mike Intruder & Fire Member
ian.cant Posted December 25, 2004 Posted December 25, 2004 May be able to help you when the shops open again, will let you know then.
breff Posted December 26, 2004 Posted December 26, 2004 Screwfix do long HSS drill bits..........If you can get on their website The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Posted December 26, 2004 Posted December 26, 2004 Screwfix do long HSS drill bits..........If you can get on their website 35536[/snapback] I seem to think they only do about 150-200mm maximum, unless they've got some 'secret stock' somewhere.
