SteveDaBeard Posted February 28, 2024 Posted February 28, 2024 I've decided to run with a new Texecom intruder alarm system, however I have a few questions. My father in law has asked Texecom, but they're a bit casual on getting back to us. Is anyone here familiar with their kit please? My questions are red in the table below.... Can I assume the two following panels are the same except for the case? Texecom Premier Elite 24 Control Panel Metal CAA-0004 Texecom Premier Elite 24 Control Panel (Plastic?) CAA-0026 Can I assume the following item is correct for the above panels Texecom Premier Elite iProx Kit includes iProx and External iProx Reader BBC-0001 Can I assume the following reader is to have an additional reader once the above iProx has been installed? Texecom External IProx Reader Access Control BBB-0001 Will I need to order the following Tags, or are some included with the iProx Kit? Texecom Premier Elite Proximity Tags (Pack of 5) CDB-0001 Is the following item correct for the Texecom Premier Elite 24 Control Panel? Texecom Connect SmartCom Ethernet & Wifi Communicator CEL-0001 Is the following item correct for the Texecom Premier Elite 24 Control Panel? Texecom Premier Elite Standard LCD Remote Keypad DBA-0001 Texecom Premier Elite LCDL Large Screen Remote Keypad DBB-0001 Presumably I won't need this if I have the BBC-001 iProx kit? Texecom Premier Elite LCDLP Large Screen & Proximity Remote Keypad DBD-0002 Are the following items correct for the Texecom Premier Elite 24 Control Panel? Texecom Ricochet Wireless Micro Door Contact Midnight Black GHA-0014 Texecom Odyssey X-BE Grade 2 Sounder with Integral Backlight WDC-0001 Premier Odyssey X-BE External Sounder Backplate c/w Backlight Louder! WDC-0002 Are the following detectors correct for the Texecom Premier Elite 24 Control Panel? Texecom Ricochet Impaq SC-W VIBER Wireless Shock and Contact White GJA-0001 Texecom Ricochet Wireless P15-W Capture 15m PIR Detector GDA-0001 Texecom Ricochet Wireless Q20-W Capture 20m Quad PIR Detector GDB-0001 Pyronix Enforcer Wireless 12m Dual Technology PIR Detector KX12DT3-WE Thanks in advance for useful answers Quote
sixwheeledbeast Posted February 28, 2024 Posted February 28, 2024 Support for products are for trade installers. 1 Mostly, PCB and Software same. Cab allows larger standby and larger output PSU. 2 iProx will work 3 It's extra outdoor reader, pretty sure it's one external reader per iProx 4 No tags come with iProx 5 Smartcom is compatible but need a trade account to register for Cloud only "DIY option" is GSM-COM 6 Either but neither is Prox 7 This is where you start to seem completely lost - it's just another keypad variant with Prox and yes you'll need a keypad. 8 You haven't got a wireless system, most bells will work but I wouldn't use a backlit one. 9 Again not wireless system and a random Enforcer passive...!? I think you should seriously consider getting a quote for someone to do it, if you value your time and security. Your not sure on product types or what is compatible and how it goes together. Very little of it will come with a manual, some older stock may have a quick leaflet but not the panels. Whatever your trying to do with this iProx stuff will rely on good programming knowledge to get working, I'd query the design. Quote
SteveDaBeard Posted February 28, 2024 Author Posted February 28, 2024 Thanks sixwheeledbeast for your comments and they're noted. Your comment No.8 says I haven't got a wireless system. however I was led to believe CAA-0004/26 was wireless and wired. Have I been misled? Quote
sixwheeledbeast Posted February 28, 2024 Posted February 28, 2024 It's a wired panel that could be expanded into wireless with extra kit but it's NOT wireless or hybrid OOTB. Quote
SteveDaBeard Posted February 28, 2024 Author Posted February 28, 2024 Thanks sixwheeledbeast for high lighting the shortfall of the CAA-0004/26 panels. Basically I forgot to add the Premier Elite 8XP-W (Part code GCD-0001). You also said "most bells will work but I wouldn't use a backlit one". What's your reason for not using a backlit unit please? I was going to mount it inside a non Texecom cover as I have several kicking around. Quote
sixwheeledbeast Posted February 28, 2024 Posted February 28, 2024 There can be unforeseen planning permission issues and they are unnecessary light pollution. You can fit them without connecting the backlight on the X's, but can purchase the twin siren non-X ones for similar price. Covering a new box with what I guess is some old C-Type cover would remove the deterrent of a shiny new box and reduce sound output. If you are thinking of not buying a lid for this sounder it just will not work, they need a compatible lid. 1 Quote
SteveDaBeard Posted February 28, 2024 Author Posted February 28, 2024 The site issue is that its remote with the near neighbours or tarmacked road, they're over a mile away, so need it as loud as possible! If after install and not being able to hear it a couple of fields away (to the neighbours) I'll add an extra sound bomb or two LOL. Isolating the back light is not a bad idea. My reason for this choice was it claims to be louder. I'll check out the lid sizing though. Once again, thank you Quote
MrHappy Posted February 28, 2024 Posted February 28, 2024 8 minutes ago, SteveDaBeard said: so need it as loud as possible! If after install and not being able to hear it a couple of fields away (to the neighbours) I'll add an extra sound bomb or two LOL. Mice fart louder than most current external sounders Sticking lots of stuff on the alarm means lost of current drawn in alarm all my P24 need 9Ah batterys 1 Quote Mr Veritas God
sixwheeledbeast Posted February 28, 2024 Posted February 28, 2024 Sound bombs are bin fodder. It sounds like something that has high enough risk that I'd be thinking needs signalling. Quote
SteveDaBeard Posted March 2, 2024 Author Posted March 2, 2024 Before I hit the buy now buttons, can anyone confirm the following items will work with one another, then the only items I will need is sensors and bell/siren boxes? Texecom Premier Elite iProx Kit includes iProx and External Prox Reader BBC-0001 Texecom Premier Elite 24 Control Panel Metal CAA-0004 Texecom Connect SmartCom Ethernet & Wifi Communicator (no prox) CEL-0001 Texecom Ricochet Premier Elite IXP-W Expansion Pack (8XP-W) GEC-0002 Texecom Premier Elite LCDLP-W Wireless LCD Keypad GCE-0001 Thanks in advance Quote
