Alarmocos Posted March 14, 2024 Posted March 14, 2024 Hi, What is the most reliable, commonly installed hybrid panel (approx 8 wired and 6 wireless zones) that has smart control via a phone app? I’m replacing a 9751, with a new panel and delta bell and would appreciate panel recommendations. The alarm should notify via the app when it goes off and can be reset or armed and disarmed via the phone. What is the most recommended panel currently? Quote
al-yeti Posted March 14, 2024 Posted March 14, 2024 53 minutes ago, Alarmocos said: Hi, What is the most reliable, commonly installed hybrid panel (approx 8 wired and 6 wireless zones) that has smart control via a phone app? I’m replacing a 9751, with a new panel and delta bell and would appreciate panel recommendations. The alarm should notify via the app when it goes off and can be reset or armed and disarmed via the phone. What is the most recommended panel currently? Diy? Quote
james.wilson Posted March 14, 2024 Posted March 14, 2024 as above dest for diy is a lot different to best. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted March 14, 2024 Posted March 14, 2024 2 hours ago, Alarmocos said: Hi, What is the most reliable, commonly installed hybrid panel (approx 8 wired and 6 wireless zones) that has smart control via a phone app? I’m replacing a 9751, with a new panel and delta bell and would appreciate panel recommendations. The alarm should notify via the app when it goes off and can be reset or armed and disarmed via the phone. What is the most recommended panel currently? Diy , one way scantronic ion range with free app base Everything else will be junk or need installer or tech support Unless someone else remembers anything else Otherwise going to the depths of diy ring? Quote
Alarmocos Posted March 14, 2024 Author Posted March 14, 2024 Thanks, it would be a DIY change over from 9751 to the new panel (I’m a spark and don’t do alarm installs, but happy to tackle my own). The ion is a good recommendation. The other panel I looked at was the Pyronix Euro, is that one best avoided? Thank you for the help and advice so far. Quote
MrHappy Posted March 14, 2024 Posted March 14, 2024 19 minutes ago, Alarmocos said: (I’m a spark and don’t do alarm installs, but happy to tackle my own). I work for lots of electrical contractors, I'd assume you'd have you own contacts Depending on what you've got & how's it fitted- CP-20, PE64-W or Euro 46 + Radio Zem I can probably change the controls in 1-2 hour, 15 mins a device & 30 mins for a sounder Nobody is producing consumer equipment, its all quirky... Quote Mr Veritas God
james.wilson Posted March 14, 2024 Posted March 14, 2024 1 hour ago, MrHappy said: Nobody is producing consumer equipment, its all quirky... or not very good Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted March 14, 2024 Posted March 14, 2024 3 hours ago, MrHappy said: I work for lots of electrical contractors, I'd assume you'd have you own contacts Depending on what you've got & how's it fitted- CP-20, PE64-W or Euro 46 + Radio Zem I can probably change the controls in 1-2 hour, 15 mins a device & 30 mins for a sounder Nobody is producing consumer equipment, its all quirky... Ion is not bad for diy if you already know the scanny menus generally You quote the orisec? And texe? Both more difficult and the euro with zem complicated for diy ? What you saying blood? Quote
MrHappy Posted March 14, 2024 Posted March 14, 2024 Just now, al-yeti said: Ion is not bad for diy if you already know the scanny menus generally You quote the orisec? And texe? Both more difficult and the euro with zem complicated for diy ? What you saying blood? All commercial controls are much of a muchness, I did an ION 10 recently, I find them much harder than a euro, orisec or texecom There is no DIY controls, everything is based on assumed knowledge Quote Mr Veritas God
Alarmocos Posted March 15, 2024 Author Posted March 15, 2024 22 hours ago, MrHappy said: I work for lots of electrical contractors, I'd assume you'd have you own contacts Depending on what you've got & how's it fitted- CP-20, PE64-W or Euro 46 + Radio Zem I can probably change the controls in 1-2 hour, 15 mins a device & 30 mins for a sounder Nobody is producing consumer equipment, its all quirky... Good point, rather than me spending a week researching, fitting and setting up a consumer panel. I’d be better arranging an installer to spend half a day installing the best panel/sounder. I’m assuming different installers have a preference for different panels, or is there a front runner that is a highly rated for most installers? (cost of the panel is not a factor, I’d rather pay a bit more for quality and function, given the length of time it will be there). Many thanks for all the responses to date and steering me in the right direction. Quote
