Guest oascctv Posted December 29, 2004 Posted December 29, 2004 Can anyone tell me how to correctly wire a Texecom Speech Dialler to an Accenta Ideal panel please ?.
Guest Posted December 29, 2004 Posted December 29, 2004 If you have both manuals it should be fairly easy. Off the top of my head the outputs are labelled PA Fire etc... on the ideal and the speech dialler has it's numbered inputs assigned to a message. Connect them up and make a note of which output from the panel is connected to which input on the dialler and program the messages relative to the input. The trigger settings are all correct as default. If you read the manuals a couple of times it becomes clearer.
Guest oascctv Posted December 30, 2004 Posted December 30, 2004 Thanks Stuart. I'll give it a go and report back.
