Scantronics 9448 zone omits
Guest Buncers
Guest Buncers
Hello,
I'm new to the forum. I have just moved into a house with a 9448. I have the user code and can full set it. I would like to part set it and omit zone 1, unfortunately when I follow the instruction it doesn't omit zone 1. I can however omit zone 2.
Anyone out there got any advice? :!:
Sounds like you have an old 9448, you can only omit zones 2 or 3. Zone 1 can be reprogrammed to act as an entry zone when part set but you will need to call an engineer to crash and reprogram it. If you post your location Im sure someone will be able to help.
  • 4 weeks later...
Guest Buncers
I opened up the control box and tried a factory reset. . Did not work - my user set access code is still working and the factory defaults don't.
Anyway I attached a new PIR and rewired some of the zones. So that the zone I wanted to omit is now on an ommitable zone.
Why the idiot that installed it didn't do that in the first place beats me.
Now, I can set the alarm (with a zone omitted) at night time while I'm in the house.
Thanks for all the help (well actually one response) :)
[/b]Please do not post information on defaulting panels in the public forums!!!
