mrala Posted May 4, 2024 Posted May 4, 2024 I need to extend the cable connected to the external alarm bell. If I enter the engineer code, can I then extend the cable without fear of the alarms being activated? Mrala Quote
MrHappy Posted May 4, 2024 Posted May 4, 2024 7 minutes ago, mrala said: If I enter the engineer code, can I then extend the cable without fear of the alarms being activated? The bell should ring as soon as the power is removed regardless of whether its on day or engineering mode If the alarm is old, diy or fitted by a muppet, it might or it might not ?? Quote Mr Veritas God
sixwheeledbeast Posted May 4, 2024 Posted May 4, 2024 You can't, they are designed that way...! Quote
james.wilson Posted May 4, 2024 Posted May 4, 2024 As above you need to disable the sab, self actuating bell in the bell. As H if its not pro gear or not installed properly then it probably won't work as it should Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
mrala Posted May 4, 2024 Author Posted May 4, 2024 Thanks to all for those helpful comments. Much appreciated. The muppet is the wiser!! Mrala Quote
