MrHappy Posted May 8, 2024 Posted May 8, 2024 1 minute ago, al-yeti said: I assume this isn't one the old texecom PSU problems ? As I understand it the PSU comes from Elmdene, when they failed they just stopped producing voltage. 1 hour ago, JOHNNYH said: It is the control panel at set times causing this loss of power, 12V dipping for 50ms at 10 Seconds in to a minute and at 40 seconds in to a minuet Compare it the ones o your the PSU2000XP's Quote Mr Veritas God
MrHappy Posted May 8, 2024 Posted May 8, 2024 (edited) 9 hours ago, JOHNNYH said: If you know your stuff ? you will know the average person does not own Keysight oscillosope Every possible measurement needed to commission and diagnose an intruder alarm can be done with multimeter If you have property large enough to need 5 expanders & lots of expensive test equipment I would assume some with your qualifications & talent could earn more more doing your own job & pay a proper alarm co. to provide a working complaint system rather faff around wasting time & money doing it poorly. Edited May 8, 2024 by MrHappy 1 Quote Mr Veritas God
JOHNNYH Posted May 8, 2024 Author Posted May 8, 2024 2 hours ago, james.wilson said: if you run it only on the battery does the comms issues stop? if yes psu issue if no not psu issue its definetly not normal running on battery, the problem stops, no dip of 12V at every 10sec or 40sec the network supply is 100% stable until mains ins applied and the onboard PSU kicks in regards 1 hour ago, al-yeti said: I assume this isn't one the old texecom PSU problems ? I have only just started to evaluate texecom elite 88 so a little new to the scene what was the old texecom psu issues ? Quote
MrHappy Posted May 8, 2024 Posted May 8, 2024 - PE 168, now much smaller system than it was for 20 years as a P168, each building has at least 1 psu, cables run under the public roads Quote Mr Veritas God
MrHappy Posted May 8, 2024 Posted May 8, 2024 37 minutes ago, JOHNNYH said: what was the old texecom psu issues ? spikes killed them, I've done PE24's between Edinburgh & London this yeat & don't go back I also do Euro's & Orisec & don't have ay real issues with anything. Al doesn't do Texecom using more exclusive equipment... Quote Mr Veritas God
JOHNNYH Posted May 8, 2024 Author Posted May 8, 2024 20 minutes ago, MrHappy said: - PE 168, now much smaller system than it was for 20 years as a P168, each building has at least 1 psu, cables run under the public roads why on earth is there a 140 network errors ??? Quote
JOHNNYH Posted May 8, 2024 Author Posted May 8, 2024 13 hours ago, sixwheeledbeast said: Battery load test is done daily with a delay in hours, the duration of this load test is in secs usually 10, it's not software! You have too much kit on the system, you have used CCA cable which isn't recommended, it's a SMPS so will get choppy under heavy load. It's my standard kit and it's not normal behaviour so your speaking to the wrong people. It also sounds like you have bought the kit second hand or old stock and can't get it to work, there is a possibility you've been past off with old stock with a duff PSU being V6. Either way there are clearly installation issues. The kit isn't designed for DIY installation and neither is the Smartcom. You also need to use a proper multimeter not wintex if your diagnosing this stuff. you have used CCA cable which isn't recommended what cable is recommended ? I have even tried individually screened CAT7 local to the Alarm to expander 1 & 2 no difference Quote
MrHappy Posted May 8, 2024 Posted May 8, 2024 57 minutes ago, JOHNNYH said: what cable is recommended ? I would normally wire intruder alarm data in belden, daisy chained, screened to cabinet (normally 4mm machine screw & nut, floating at last device Quote Mr Veritas God
MrHappy Posted May 8, 2024 Posted May 8, 2024 1 hour ago, JOHNNYH said: why on earth is there a 140 network errors ??? 25+ year old cables, 20year old expanders, cable length, water in man holes, length of time its measured ? its not a problem site,, so never tried to fixe it. Quote Mr Veritas God
james.wilson Posted May 9, 2024 Posted May 9, 2024 3 hours ago, JOHNNYH said: running on battery, the problem stops, no dip of 12V at every 10sec or 40sec the network supply is 100% stable until mains ins applied and the onboard PSU kicks in regards looks like a panel / psu problem then. If it stable without the mains. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
