Hi I got a visonic powermax alarm unit it works fine but needed to know how todo part settings for alarm to arm door contacts for night only any help would be greatfull thanks
You can but we don't give advice on how to defeat systems which a default does.
I'm sure you are genuine but others are not.
Not sure if aft badged gear has different firmware stopping it's use as generic visonic maybe someone else here with experience knows?
19 minutes ago, james.wilson said:
Hi James thanks for getting back to me if I can default the panel can the powermaster 30 do partset options for night time please let me know thanks
I believe different frequency prevents the use of normal visonic devices
