Stef Posted July 8, 2024 Posted July 8, 2024 (edited) Hi, please help if you can! Our door sensor cable was accidentally cut and a new cable was installed in our Veritas Excel and now every time you go to set the alarm with your 4 digits the 7 lights up and the internal system beeps repeatedly 7 times. We have tried the walk through and tried to eliminate the zone, but being that it’s zone 7 (tamper) on the main unit, it won’t let us bypass. Also the #### and #### access level codes do not work Edited July 8, 2024 by sixwheeledbeast Proper topic.. no codes in posts please. Quote
sixwheeledbeast Posted July 8, 2024 Posted July 8, 2024 You have likely blown a fuse, why you have power going to the contact is beyond me tho. The codes are unlikely to be the default ones so pointless trying them unless you know that's right. Quote
