Kp160 and Kp250 disarming issues
Hi I got a powermaster 30 with wireless keypad kp160 and kp250 when I arm the panel it's ok but when the alarm rings the disarm option does not accept the user codes or proxy tags it only allows me to disarm the panel using the phone app any ideas please
Kind regards
Naeem
  • 2 weeks later...
1 hour ago, naeem7861 said:
Hi I still can't get it to work when alarm is activated the main keypad doesn't allow to use tag or number s
Check tag / user options
Assuming you can unset normally?
Edited by al-yeti
3 minutes ago, naeem7861 said:
Hi user permit is of on the main panel is that the problem
Don't know, I don't really know the panel
But usually if it doesn't let you unset with code it's because you have to use the proximity tag
If prox tag isn't letting you then I assuming an option is the problem with the proximity tags
