Posted (edited)
Hi everyone,
Please help me to know how to connect my volumetric motion detector (Pyronix XD10TT-AM) to my ELKRON MEDEA32 board.
The detector includes pre-installed resistors to be activated by a connection as needed (see the shared assembly).
Schema of the assembly of my Pyronix XD10TT-AM
In my MEDEA32 board, i have 6 N/C inputs.
Manual of MEDEA32
(page 24 and 25)
I have also a wired add-on Elkron EP708 expansion with 8 points PGM input/output (PrIO).
Manual of EP708
1) According to the assembly diagram, should I use programmed input (PGM) or the simple N/C input can be used ?
2) Which point on my MEDEA32 board that corresponds to the input (COM) on the assembly of my pyronix.
Some board have zone with a groupe of "AT input / EOL and COM". But this is not the case in my MEDEA32 or the EP708 add-on.
Here is an exemple of PCX46 (Pyronix)
Thanks a lot
Edited by Hack
orthograph
20 minutes ago, Hack said:
Hi everyone,
Manual of MEDEA32
(page 24 and 25)
Manual of EP708
Thanks a lot
So your just using the AA and TT terminals in that case without eol and without any resistors
Posted (edited)
thaks al-yeti 😁
I understand that without resistor is functionnal like you said.
But the constructor recommand the use of two transistor to avoid false alarms and short circuits.
I just need to know the equivalent of (COM) in my MEDEA32 board or the add-on EP708.
Edited by Hack
28 minutes ago, Hack said:
thaks al-yeti 😁
Lol
I tried to look at manual it's as bad as other manuals
Thanks a lot Al yeti 🙏
I can't use the pre installed resistors in my Pyronix XD10TT because my board ELKRON recommand others (5,11-10 and 15kOhm)
Then, i must install them manually like this 🧐
Ok but you don't have to use the fault
