Mike TV Posted August 7 Share Posted August 7 I have an installation which runs PoE around 80m to a PoE splitter, then off to one camera 1m away and another camera aroun 5m away, which was working successfully for a number of months and now isn't. Any iseas as to why this would stop working? I am considering installing a new PoE switch to replace the splitter, would this work? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 7 Share Posted August 7 It depends on the wattage of the devices but 80m is a long way. You have to consider other devices on the switch and the overall budget, maybe they are now drawing more current than from installation, affecting the longest run. PoE switch at the splitter point would be sensible, yes. Quote Link to comment Share on other sites More sharing options...
Mike TV Posted August 7 Author Share Posted August 7 Thanks for your feedback SWB, appreciated. I will perform a test with a POE switch at the splitter and see if it works. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 7 Share Posted August 7 1 hour ago, Mike TV said: Thanks for your feedback SWB, appreciated. I will perform a test with a POE switch at the splitter and see if it works. Ideally get power that end , if you can follow the existing cable with power cable of appropriate type Quote Link to comment Share on other sites More sharing options...
Mike TV Posted August 7 Author Share Posted August 7 My plan is to get power supply to the new PoE switch location, is that what you mean? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 7 Share Posted August 7 Is the poe source big enough to run it all? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Mike TV Posted August 7 Author Share Posted August 7 Well I am hoping the POE switch I install (with power supply) in place of the splitter will power the two cameras which are too far from the main PoE switch to draw power. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 7 Share Posted August 7 just be caution as some cameras require POE+ and most switches cant do that Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted August 7 Share Posted August 7 2 hours ago, Mike TV said: My plan is to get power supply to the new PoE switch location, is that what you mean? Yes once power is done just install switch there and it will probably work Quote Link to comment Share on other sites More sharing options...
PeterJames Posted August 8 Share Posted August 8 why did you not put the original poe where the splitter is? Quote Link to comment Share on other sites More sharing options...
