Gary M Posted August 30, 2024 Posted August 30, 2024 Keypad is showing the following message: INSTALLER EXIT FLTS Z01 T Front door Any idea how I reset alarm? Quote
james.wilson Posted August 30, 2024 Posted August 30, 2024 Looks like you have a tamper on that circuit. What has happened? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Gary M Posted August 31, 2024 Author Posted August 31, 2024 I put the keypad into engineer mode and changed the battery in the front door sensor. I now cannot reset system. The main button on the panel is glowing red, not green. Quote
sixwheeledbeast Posted August 31, 2024 Posted August 31, 2024 I'd take the front door contact apart remove battery, make sure you have seated the battery correctly then try to reset again. If the system still thinks the contact is in fault you can't clear down. Quote
al-yeti Posted August 31, 2024 Posted August 31, 2024 2 hours ago, Gary M said: I put the keypad into engineer mode and changed the battery in the front door sensor. I now cannot reset system. The main button on the panel is glowing red, not green. Front door sensor will have a small switch spring to show the contact has closed , probably you didn't close it properly or perhaps broke or dropped the spring or something along those lines Quote
