Logic 4 Query
Guest monkey_puzzle
Guest monkey_puzzle
We have an alarm system installed in our outbuildings/stables that has a Logic 4 control panel. We don't have any instructions left by the previous owners. The alarm seems to work OK (by setting to full) although I am guessing that it is quite an old system being key operated. It would be helpful to know which sensors are covered by the part set - I was wondering if I could find this out using the test mode? If so can anyone offer any advice as to how the test mode works?
Thanks in anticipation.
Hi , the default setting is zone 2 as part set, but this is engineer selectable by pins inside the panel.Your best bet is to do a walk test , find out where your detection devices are , and see which work in FULL set and which one (if any) is omitted in PART.
