luke5853 Posted September 15 Posted September 15 I have recently installed a new veritas r8 panel, with the remote keypad and 6 capture p15 and 2 door contacts. All PIRs illuminate when activated, door contacts work as expected. No tampers on system. When arming the system or preforming a walk test the PIRs illuminate but do not register on the keypad. Any advice would be great Quote
MrHappy Posted September 15 Posted September 15 on the back of the sensor there is slide for eol vaule it needs to be n/c... Quote Mr Veritas God
luke5853 Posted September 15 Author Posted September 15 (edited) @MrHappy thank you. Little confused as the guide states "The device is defaulted to the Texecom EOL values. Use a terminal driver to move the switch to any other position. The O/C position can be used for other wiring types, including use of resistor values which are not included on the device Terminal block identification." Obviously both items are texecom so why would I change it to o/c. Thanks you Edited September 15 by luke5853 Quote
sixwheeledbeast Posted September 15 Posted September 15 The Veritas is a double pole panel so you need normally closed devices (without resistors). The Texecom setting on the Capture PIR's is for Texecom EOL circuits. Quote
al-yeti Posted September 15 Posted September 15 4 minutes ago, luke5853 said: @MrHappy thank you. Little confused as the guide states "The device is defaulted to the Texecom EOL values. Use a terminal driver to move the switch to any other position. The O/C position can be used for other wiring types, including use of resistor values which are not included on the device Terminal block identification." Obviously both items are texecom so why would I change it to o/c. Thanks you As you set your panel non eol and pirs are eol , so you would change it Just now, sixwheeledbeast said: The Veritas is a double pole panel so you need normally closed devices (without resistors). The Texecom setting on the Capture PIR's is for Texecom EOL circuits. This is the posh answer Quote
MrHappy Posted September 16 Posted September 16 4 minutes ago, luke5853 said: Thanks all. This resolved the issue. I've only do this 30 odd years Quote Mr Veritas God
