You could use a hammer...
Being serious, if you have an installer speak to them first as the system may lock out if you tamper with it.
Texecom keypads can be wireless or wired but not WiFi, the small fine threaded screw is underneath to remove the front.
Upon freeing the front from the backplate the alarm will sound a tamper alarm and you will have to silence and reset this when you put it back together.
It's possible you will end up with a non-functional system if you mess anything up.
