al-yeti Posted October 22 Posted October 22 On 18/10/2024 at 16:45, garnayrob said: Thanks, I did look at options to temporarily provide a battery feed, but in the end I let the alarm sound for 15mins (pre-warning neighbours in advance)!! Bell on battery , but I am feeling nervous already 1 Quote
garnayrob Posted October 22 Author Posted October 22 1 hour ago, al-yeti said: Bell on battery , but I am feeling nervous already Let me know how it went!! Quote
al-yeti Posted October 22 Posted October 22 8 minutes ago, garnayrob said: Let me know how it went!! Basically took 20seconds once prepped 1 Quote
al-yeti Posted October 22 Posted October 22 38 minutes ago, al-yeti said: Basically took 20seconds once prepped NOT Pretty but getting there after a few clips and cable ties Mr H what you think ? If passes you then I need try worse Quote
MrHappy Posted October 22 Posted October 22 2 hours ago, al-yeti said: Mr H what you think ? If passes you then I need try worse You didn't even angle grind anything ? Quote Mr Veritas God
al-yeti Posted October 22 Posted October 22 21 minutes ago, MrHappy said: You didn't even angle grind anything ? Yeah ok ok next time Quote
MrHappy Posted October 22 Posted October 22 (edited) 57 minutes ago, al-yeti said: Yeah ok ok next time Does your Irish tat have a radio receiver built in ? Then you add gsm / wifi card for comms ? Edited October 22 by MrHappy Quote Mr Veritas God
al-yeti Posted October 22 Posted October 22 33 minutes ago, MrHappy said: Does your Irish tat have a radio receiver built in ? Then you add gsm / wifi card for comms ? RF built WiFi/ Lan/ gsm choice Quote
MrHappy Posted October 22 Posted October 22 8 minutes ago, al-yeti said: RF built WiFi/ Lan/ gsm choice Last time I logged onto SW I can now see pricing, which quite a bit better than I assume it would be... Quote Mr Veritas God
al-yeti Posted October 22 Posted October 22 2 minutes ago, MrHappy said: Last time I logged onto SW I can now see pricing, which quite a bit better than I assume it would be... Public Quote
