Pyronix Enforcer - backplate replacement
On 18/10/2024 at 16:45, garnayrob said:
Thanks, I did look at options to temporarily provide a battery feed, but in the end I let the alarm sound for 15mins (pre-warning neighbours in advance)!! 😆
Bell on battery , but I am feeling nervous already
  • Replies 21
  • Views 3.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Depends how it's all wired tho, if your going to take time you can disconnect and send power to it via a battery , otherwise as above I guess    Keep windows and doors closed that way it doe
  • james.wilson
    james.wilson
    This is the reason you use proper gear. Diy stuff can be disabled but what would you prefer an off switch? Or worse an off code. You have found out that compliant equipment does as it says.
  • Although bell can be reconnected within a min or two of you skilled enough    I would have let the old panel hand some how cut the plastic or something got the new back plates in and powered
Posted Images
😄 Let me know how it went!!
Basically took 20seconds once prepped
NOT Pretty but getting there after a few clips and cable ties
Mr H what you think ? If passes you then I need try worse 😂
You didn't even angle grind anything ?
57 minutes ago, al-yeti said:
Yeah ok ok next time
Does your Irish tat have a radio receiver built in ?
Then you add gsm / wifi card for comms ?
Edited by MrHappy
RF built
WiFi/ Lan/ gsm choice
RF built
Last time I logged onto SW I can now see pricing, which quite a bit better than I assume it would be...
Public
