bm99 Posted October 23, 2024 Posted October 23, 2024 Hi all, i have a hikvision KV6113 - WPE1 C doorbell Im upgrading my DVR which is also going to have some IP cams added and want to pull the stream of the doorbell in. Am i limited with which recorder can i use or can i bring the stream into any DVR which also has Ip cams added? Quote
al-yeti Posted October 23, 2024 Posted October 23, 2024 2 hours ago, bm99 said: Hi all, i have a hikvision KV6113 - WPE1 C doorbell Im upgrading my DVR which is also going to have some IP cams added and want to pull the stream of the doorbell in. Am i limited with which recorder can i use or can i bring the stream into any DVR which also has Ip cams added? I think any , but have to connect it manually on the NVR on spare channel using it's IP address etc Hik connect as seperate unit for the call ring features Hate hik lol Quote
bm99 Posted October 24, 2024 Author Posted October 24, 2024 9 hours ago, al-yeti said: I think any , but have to connect it manually on the NVR on spare channel using it's IP address etc Hik connect as seperate unit for the call ring features Hate hik lol lol what do you guys use, dahua? Quote
PeterJames Posted October 24, 2024 Posted October 24, 2024 I hate Hik too but if you can set the protocol to onvif on the Dbell then your DVR should find it Quote
al-yeti Posted October 24, 2024 Posted October 24, 2024 2 hours ago, PeterJames said: I hate Hik too but if you can set the protocol to onvif on the Dbell then your DVR should find it I didn't think you needed to do that him dB to hik dVR/NVR? 7 hours ago, bm99 said: lol what do you guys use, dahua? Actually the dahua doorbell is pretty good Quote
PeterJames Posted October 24, 2024 Posted October 24, 2024 50 minutes ago, al-yeti said: I didn't think you needed to do that him dB to hik dVR/NVR? Depends on the DVR some wont see other brands but they should all see Onvif. Most cams are sending out Onvif but I wouldnt know if the Hik doorbell does Quote
bm99 Posted October 25, 2024 Author Posted October 25, 2024 15 hours ago, al-yeti said: I didn't think you needed to do that him dB to hik dVR/NVR? Actually the dahua doorbell is pretty good But i wont be using a HIk DVR brand, will be either Uniview or Serage Quote
james.wilson Posted October 25, 2024 Posted October 25, 2024 test it with VLC i dont like hik either but if it can rtsp you should be able to get it on nvr Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted October 25, 2024 Posted October 25, 2024 1 hour ago, bm99 said: But i wont be using a HIk DVR brand, will be either Uniview or Serage Then as above you need onvif which uniview probably will work better than serage , latter being total junk and uni more or less copy of hik Quote
bm99 Posted October 25, 2024 Author Posted October 25, 2024 (edited) 1 hour ago, al-yeti said: Then as above you need onvif which uniview probably will work better than serage , latter being total junk and uni more or less copy of hik only reason i prefer serage is 4 cams to be viewed through the app. everything else is just 1 cam on playback, small thing but just feature we want I know the Hik db can do rtsp but never used it, hik have sent the rtsp guide just going to read it and see Also have checked with them and DB doesnt support onvif Edited October 25, 2024 by bm99 Quote
