al-yeti Posted October 25, 2024 Posted October 25, 2024 5 minutes ago, bm99 said: only reason i prefer serage is 4 cams to be viewed through the app. everything else is just 1 cam on playback, small thing but just feature we want I know the Hik db can do rtsp but never used it, hik have sent the rtsp guide just going to read it and see Also have checked with them and DB doesnt support onvif dB, is it Poe ? Quote
al-yeti Posted October 25, 2024 Posted October 25, 2024 2 minutes ago, al-yeti said: dB, is it Poe ? Actually forget that, you're better off with the dahu bell, hikvision doorbell which has on they do various but I'm not sure what you mean by single channel playback as the hic and other recorders do playback more than one channel I assume you have a limited budget which is fair enough Quote
PeterJames Posted October 25, 2024 Posted October 25, 2024 57 minutes ago, bm99 said: only reason i prefer serage is 4 cams to be viewed through the app. everything else is just 1 cam on playback, small thing but just feature we want I dont think Ive come across an app that cant do that? Dahua and Hik does it? Quote
james.wilson Posted October 25, 2024 Posted October 25, 2024 Smartphone app vs pc app? The 1 way playback on phone app is probably a bandwidth thing unless dual stream recording Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
bm99 Posted October 25, 2024 Author Posted October 25, 2024 Ive got Hik, uniview and serage apps and all but the serage when on playback mode on the app only playback 1 camera at the same time, you can see others but then when u select another camera the previous pauses Hence the change of brand Quote
james.wilson Posted October 25, 2024 Posted October 25, 2024 In my case 9 Yr old ahd unit does 4 way playback in app and 16 way if wanted on pc. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
PeterJames Posted October 27, 2024 Posted October 27, 2024 On 25/10/2024 at 19:58, bm99 said: Ive got Hik, uniview and serage apps and all but the serage when on playback mode on the app only playback 1 camera at the same time, you can see others but then when u select another camera the previous pauses Hence the change of brand Im fairly certain Hik does play back more than 1 camera, when in playback just add more cameras Dahua definately does do it I have just tried it. Quote
al-yeti Posted October 27, 2024 Posted October 27, 2024 3 hours ago, PeterJames said: Im fairly certain Hik does play back more than 1 camera, when in playback just add more cameras Dahua definately does do it I have just tried it. Serage cheaper maybe Quote
PeterJames Posted October 28, 2024 Posted October 28, 2024 20 hours ago, al-yeti said: Serage cheaper maybe Never heard of Serage so your probably right Quote
bm99 Posted October 29, 2024 Author Posted October 29, 2024 def hik doesnt have syncronos playback meaning if you forward or jump to say 7am only that 1 camera with a red box around it will move forward the rest will continue to play from original time (12am) Quote
