Anj Posted 4 hours ago Share Posted 4 hours ago I have Scantronic 9651 installed. Due to some work, the builder removed the fuse from the Fused Mains Spur connected to the Control Unit. Then he lost the fuse and never put it in for 3 weeks. The PIR beeped a lot and then went silent and the builder has left! I have replaced the 3Amp fuse but the Keypads have no power. What can I do? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted 1 hour ago Share Posted 1 hour ago 2 hours ago, Anj said: I have Scantronic 9651 installed. Due to some work, the builder removed the fuse from the Fused Mains Spur connected to the Control Unit. Then he lost the fuse and never put it in for 3 weeks. The PIR beeped a lot and then went silent and the builder has left! I have replaced the 3Amp fuse but the Keypads have no power. What can I do? Unless you have some knowledge for this it will be difficult. I would remove the fuse again You need logically check for electrical power , How do you know the mains power is not disconnected somewhere? After inserting fuse that would be your first check , by maybe using a mains tester. Quote Link to comment Share on other sites More sharing options...
