kudos Posted December 16, 2024 Posted December 16, 2024 I have a property with a quite old Guardtec 800 system in it. Its been maintained over the years by a local security company and during that time a couple of the PIR sensors have been replaced. All in all, it still works fine. Ive gotten to to the stage it would be nice to bring things a little more up to date and have remote access on a mobile phone to Set/Un-Set the alarm and also get alarm notifications. Obviously I appreciate there is a lot more that modern systems can do, but those things I list are the real focus of what I need. As a secondary option it would be nice to have some form of API connectivity so I could connect it into a home automation system for alerts and the set/un-set, but this is a very minor concern. Im 99% sure that everyone will say "just replace the board with a new one" and from what I can tell, the company that installed/maintained this alarm now use Texecom systems. What I would like to know before I approach them is: 1) Will/should a new Texecom alarm panel work with: - My current PIR sensors - My current Door sensors - My current Alarm siren box I suspect the answer is yes with the PIR and door sensors and I am uncertain about the Alarm siren. 2) Is there any way with the current Guardtech to get access into its UART/Serial port and send set/un-set commands as well as alarm alerts or is the tech that allowed that possibility the preserve of dead technology OR only authorised to Professional installers by Risco (whom I understand bought Guardtec back in 200X). Thanks in advance for any answers. Quote
sixwheeledbeast Posted December 16, 2024 Posted December 16, 2024 1) In most cases yes but updating them should be considered. I would usually say on a takeover upgrade ideal is to replace the electronics and test the wiring is sound for re-use. 2) Forget the Gardtec if you need to update. It EOL, better to replace at your convenience before your forced to by a failure. Quote
PeterJames Posted December 16, 2024 Posted December 16, 2024 Hi Yes to all your questions re the kit and Texe. The 800 is quite an old panel and long obsolete now. there are varios outputs on the panel itself I doubt you will get anything useful from the serial that panel predates SIA and only sent pin outs, but you can program a zone as a keyswitch to arm disarm it. I dont install Texe as a rule but I do know that the premier does talk to a specific home automation system but I cant remember what it is. Personally I use home assistant and a input output module from my alarm panel is connected to my server via ESP 32. But I only use it to switch my lights on and off etc no more than that. The panel I use comes with its own app which is probably a more secure and reliable way to notify me when the alarm has activated etc Quote
kudos Posted December 18, 2024 Author Posted December 18, 2024 @PeterJames@sixwheeledbeast Thanks for your replies. Really appreciated. I guess I will give it a think over on my christmas break and have a chat with the local installer company in the new year. Have a good christmas/new year. Quote
