Alan12 Posted December 23, 2024 Posted December 23, 2024 Hi All Recently doing some DIY and unfortunately made a mistake and unscrewed the screws off the lid of the alarm (needed access to something behind it in cupboard). Anyway, internal alarm went off, managed to switch this off by entering code on panel, and I put the screws back in place without removing the lid. Now the panel says "lid tamper" and can't use the alarm. Tried to contact original installer but they are not in business anymore. Can anyone provide some instructions on how to reset the alarm to get rid of this fault? Thanks Alan Quote
al-yeti Posted December 23, 2024 Posted December 23, 2024 1 hour ago, Alan12 said: Hi All Recently doing some DIY and unfortunately made a mistake and unscrewed the screws off the lid of the alarm (needed access to something behind it in cupboard). Anyway, internal alarm went off, managed to switch this off by entering code on panel, and I put the screws back in place without removing the lid. Now the panel says "lid tamper" and can't use the alarm. Tried to contact original installer but they are not in business anymore. Can anyone provide some instructions on how to reset the alarm to get rid of this fault? Thanks Alan Any local installer could do this for you, make contact and pay for service while your at it , full test job done Quote
Alan12 Posted December 23, 2024 Author Posted December 23, 2024 Thanks, yes I am aware I can contact an alarm engineer to do this. My reason for asking here is to see if this is something I can deal with, without needing to do that. Quote
al-yeti Posted December 23, 2024 Posted December 23, 2024 8 minutes ago, Alan12 said: Thanks, yes I am aware I can contact an alarm engineer to do this. My reason for asking here is to see if this is something I can deal with, without needing to do that. The problem with this is , when most make a mistake trying to do this , they wipe all the settings to default So if you couldn't find out how by now then try and avoid it, unfortunately this site does not give out that kind of information Quote
james.wilson Posted December 23, 2024 Posted December 23, 2024 id assume you havnt got the lid on correcrtly or you have damaged the tamper switch. You have done nothing else but remove the lid of the panel? its also going to need a service even if you do it yourself Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted December 23, 2024 Posted December 23, 2024 So it doesn't reset with your Master user code? You definitely have the lid on and closed the lid switch correctly? Quote
Alan12 Posted December 23, 2024 Author Posted December 23, 2024 Dont have the master reset code, the system was installed before I moved in two years ago. The default engineer code isnt working, so i think the initial installer has put in a different one to the default code. Lid definitely on properly. The lid tamper fault is "inactive", which means that the fault is no longer there. It just needs an engineer reset. I think even if I ask an engineer to come and do it, if he doesnt have the original engineer code, they will have to reset to default factory settings (perform a stage 1 reset), then re-install. @james.wilson - why would it need a service if I do it myself? Quote
james.wilson Posted December 23, 2024 Posted December 23, 2024 2 minutes ago, Alan12 said: The default engineer code isnt working, so i think the initial installer has put in a different one to the default code. This should always been changed leaving anything with default codes is a huge risk on a system designed to be secure. 3 minutes ago, Alan12 said: why would it need a service if I do it myself? All systems need to be serviced or they will eventually fail, usually at 2am etc 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Alan12 Posted December 23, 2024 Author Posted December 23, 2024 2 minutes ago, james.wilson said: This should always been changed leaving anything with default codes is a huge risk on a system designed to be secure. All systems need to be serviced or they will eventually fail, usually at 2am etc yes i understand, im sure they did change it for that reason Quote
sixwheeledbeast Posted December 23, 2024 Posted December 23, 2024 Don't use Scantronic regular but to reset a tamper I'd expect you need the Master user code if not set to Engineer Reset. Sounds like you maybe best to have it serviced and re-programmed so you have the Master code. Quote
