optima 2 plus
Guest jonno
Does anyone know where I can get sensors for the optima 2 plus, 1 to replace an existing one which is faulty and one to extend to another room, if they are not available is it possible to get sensors that are compatable with this system
Pretty much any ( I assume you mean 'PIR') sensor on the market will be compatible with your system. Please get a professional to check the system over for you as there may be other faults, and if your not competent with alarms you may not replace/install the sensors correctly, which could cost you a lot more in the long run ;)
If you don't know......ask.
