Hi there,
In the process of swapping out a first gen i-on16 with a modern i-30R.
It currently has a Version 1 i-kp01 keypad connected to it.
When powering up the kep pad is saying Press addr buttons on wired keypads.
I'm holding A and Tick down but it is not working.
Do you think this will be due to it being a version 1 keypad and it expecting to hardwire onto the bus ?
Thanks,
Roy
33 minutes ago, roydonaldson said:
Hi there,
Thanks,
Roy
It's not modern tho , discontinued so better to return or don't buy it
Get the ion40 range more or less same price
The keypad adding can be stupid , power cycle and try again
The i-on30R engineering manual says that it is compatible with the i-kp01 ( firmware version 2.0 or above ) and the V1 i-kp01 uses jumpers to set it's bus address. So, I'm guessing that the A, Tick option does not work on it and so it
cannot be learned by the panel.
I know the i-on30R is not current, but it can still get upgraded to the latest V7 firmware and connect to SecureConnect on wifi.
