ADAM90 Posted January 8 Author Posted January 8 HI Is there anyway i can stop this AUX 0 Issue? Its just went off again a few days after checking everything? Is there a way to stop this from happening again from the main control panel If there is please explain im away on holiday tomorrow and now will just have to unplug the full alarm system now Quote
sixwheeledbeast Posted January 8 Posted January 8 I still think it's the G3 part that has the fault from what you have explained so far, so wiring bell as G2 like I already said would stop the fault. The other option is getting someone in that knows what they're doing. Quote
al-yeti Posted January 8 Posted January 8 2 hours ago, ADAM90 said: HI Is there anyway i can stop this AUX 0 Issue? Its just went off again a few days after checking everything? Is there a way to stop this from happening again from the main control panel If there is please explain im away on holiday tomorrow and now will just have to unplug the full alarm system now Why not just disconnect the bell only , keep system running with internal bell Better than nothing right ? Quote
ADAM90 Posted January 8 Author Posted January 8 hi how do i wire it as a G2 ? Do i need to go up the ladders again? or can it be done at the control panel? Quote
ADAM90 Posted January 8 Author Posted January 8 13 minutes ago, al-yeti said: Why not just disconnect the bell only , keep system running with internal bell Better than nothing right ? its not that the external bell isnt going of just the internal control panel ? I mean i could disconnect it but is it the bell thats the issue? doesnt come up bell tamper, i think i have to disconnect 2 x wires? THE ORANGE AND GREEN ONES? Quote
al-yeti Posted January 8 Posted January 8 2 hours ago, ADAM90 said: its not that the external bell isnt going of just the internal control panel ? I mean i could disconnect it but is it the bell thats the issue? doesnt come up bell tamper, i think i have to disconnect 2 x wires? THE ORANGE AND GREEN ONES? So loop the tamper so only alarm circuits work But this all depends if you have a key holder looking after your place while your away Does the alarm notify anyone, so maybe no one will respond anyway Quote
MrHappy Posted January 9 Posted January 9 8 hours ago, ADAM90 said: Do i need to go up the ladders again go, go gadgets legs.... Quote Mr Veritas God
