JPW Posted January 7 Author Posted January 7 (edited) 6 hours ago, sixwheeledbeast said: What are the comfort LED's doing? Have you triggered it with a bell test or giving the trigger a negative. Comfort LED's are normal, alternating between the left and right LED's inside the box. On the keypad, if I go to Engineer Utils > Bell Test > On, the bell correctly sounds. Same for strobe when I test. This is the strange thing. The wiring must check out as the bell works when testing from the keypad respectively? Edited January 7 by JPW Quote
norman Posted January 7 Posted January 7 Did you factory default the panel on initial power up? 1 Quote Nothing is foolproof to a sufficiently talented fool.
JPW Posted January 7 Author Posted January 7 46 minutes ago, norman said: Did you factory default the panel on initial power up? Good question. I did not, assuming a brand new panel out the box would have an erased memory? Quote
sixwheeledbeast Posted January 7 Posted January 7 So you've proven the wiring and that it's likely the programming... Yes, you should always default them from new. 2 Quote
james.wilson Posted January 7 Posted January 7 If you swap the bell and strobe terminals in the panel does the bell sound and the strobe not activate? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
JPW Posted January 7 Author Posted January 7 1 hour ago, james.wilson said: If you swap the bell and strobe terminals in the panel does the bell sound and the strobe not activate? Great idea, I will try this when back on site. Quote
MrHappy Posted January 7 Posted January 7 since 30 years ago or whatever.... most 4737 / g2 bells on little jobs will have been wired at panel end by adding +/- then shorting the ring & return together before putting all the wires in the panel Quote Mr Veritas God
al-yeti Posted January 7 Posted January 7 5 hours ago, JPW said: Great idea, I will try this when back on site. Dude 100% in error you have changed something on the outputs Quote
