JPW Posted Tuesday at 07:53 Author Posted Tuesday at 07:53 (edited) 6 hours ago, sixwheeledbeast said: What are the comfort LED's doing? Have you triggered it with a bell test or giving the trigger a negative. Comfort LED's are normal, alternating between the left and right LED's inside the box. On the keypad, if I go to Engineer Utils > Bell Test > On, the bell correctly sounds. Same for strobe when I test. This is the strange thing. The wiring must check out as the bell works when testing from the keypad respectively? Edited Tuesday at 07:54 by JPW Quote
norman Posted Tuesday at 08:42 Posted Tuesday at 08:42 Did you factory default the panel on initial power up? 1 Quote Nothing is foolproof to a sufficiently talented fool.
JPW Posted Tuesday at 09:29 Author Posted Tuesday at 09:29 46 minutes ago, norman said: Did you factory default the panel on initial power up? Good question. I did not, assuming a brand new panel out the box would have an erased memory? Quote
sixwheeledbeast Posted Tuesday at 10:22 Posted Tuesday at 10:22 So you've proven the wiring and that it's likely the programming... Yes, you should always default them from new. 2 Quote
james.wilson Posted Tuesday at 15:00 Posted Tuesday at 15:00 If you swap the bell and strobe terminals in the panel does the bell sound and the strobe not activate? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
JPW Posted Tuesday at 16:59 Author Posted Tuesday at 16:59 1 hour ago, james.wilson said: If you swap the bell and strobe terminals in the panel does the bell sound and the strobe not activate? Great idea, I will try this when back on site. Quote
MrHappy Posted Tuesday at 19:18 Posted Tuesday at 19:18 since 30 years ago or whatever.... most 4737 / g2 bells on little jobs will have been wired at panel end by adding +/- then shorting the ring & return together before putting all the wires in the panel Quote Mr Veritas God
al-yeti Posted Tuesday at 22:56 Posted Tuesday at 22:56 5 hours ago, JPW said: Great idea, I will try this when back on site. Dude 100% in error you have changed something on the outputs Quote
