guyfingers Posted Wednesday at 17:39 Posted Wednesday at 17:39 Hi all Newbie here. I moved into a house which has a working Visonic PowerMaxComplete burglar alarm system with 4 PIRs, external alarm, 2 remote fobs and door sensor. A few weeks back, a surge knocked out a load of appliances, including the transformer in the alarm. Needless to say, running on the internal battery, it ran out of juice and has been dead since the transformer was replaced, It's now up and working, but my code isn't being accepted - neither is 1111 or 9999. Strange, as the fobs are working and also the door sensor. Hope it doesn't mean I'll have to do a hard reset and re-program everything TIA Guy Quote
PeterJames Posted Wednesday at 18:40 Posted Wednesday at 18:40 53 minutes ago, guyfingers said: Hi all Newbie here. I moved into a house which has a working Visonic PowerMaxComplete burglar alarm system with 4 PIRs, external alarm, 2 remote fobs and door sensor. A few weeks back, a surge knocked out a load of appliances, including the transformer in the alarm. Needless to say, running on the internal battery, it ran out of juice and has been dead since the transformer was replaced, It's now up and working, but my code isn't being accepted - neither is 1111 or 9999. Strange, as the fobs are working and also the door sensor. Hope it doesn't mean I'll have to do a hard reset and re-program everything TIA Guy That is quite bizarre panels have a Non Volatile Memory (NVM) so they normally dont lose their programming when the power is completely lost. It could be that the default codes process was activated when you powered the system back up. Not sure what the default code for the powermax would be but its normally something like 1234, 4567, 7890, 0123, 2222, ect you could run through each one to see if any of them work. Keep your fob to hand because two many wrong codes will cause tampers Quote
guyfingers Posted Wednesday at 19:52 Author Posted Wednesday at 19:52 Hey, thanks for your quick reply. Yes, it's strange that all the other items are programmed in correctly. The manual says user is 1111 and maintenance is 9999. I've tried both. Neither work I'm now beginning to think I changed it (bad memory), but have tried all my usual PINs but none has worked and it locks up for about a minute after 3 tries. Quote
james.wilson Posted Wednesday at 20:07 Posted Wednesday at 20:07 you should always chnage default codes. So id assume you did Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
guyfingers Posted yesterday at 01:58 Author Posted yesterday at 01:58 5 hours ago, james.wilson said: you should always change default codes. So id assume you did I'm afraid not - it was the day after our wedding anniversary so we kept it. I've just gone going to Installer mode - tried 8888, 9999, 1111 and 0000 - no joy (also tried 0123, 5678 and 7890) This is mad... Quote
al-yeti Posted yesterday at 03:15 Posted yesterday at 03:15 1 hour ago, guyfingers said: I'm afraid not - it was the day after our wedding anniversary so we kept it. I've just gone going to Installer mode - tried 8888, 9999, 1111 and 0000 - no joy (also tried 0123, 5678 and 7890) This is mad... You never had codes in first place then lol. Quote
sixwheeledbeast Posted 23 hours ago Posted 23 hours ago I'd say someone tried the code defaulting procedure and got it wrong or the panel is knackered. Quote
guyfingers Posted 19 hours ago Author Posted 19 hours ago 10 hours ago, al-yeti said: You never had codes in first place then lol. Apparently when it's first installed, they use 9999 or 8888 and then have to change it. Maybe I'll try to find the people that first installed it (a million years ago!) - you never know! 3 hours ago, sixwheeledbeast said: I'd say someone tried the code defaulting procedure and got it wrong or the panel is knackered. I think the latter might be right... It beeps but you don't know if pressing the 0 really does enter 0 Quote
guyfingers Posted 17 hours ago Author Posted 17 hours ago I've bitten the bullet and going to pay for KAT to come over and sort it out. I've spent too much time on it already! Thanks for your help and advice, all. Quote
james.wilson Posted 7 hours ago Posted 7 hours ago Kat? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
