ashs Posted Monday at 08:03 Posted Monday at 08:03 I'd like to have an additional keypad for my alarm system. Is it straightforward to add one? It will be right next to the main Galaxy panel. Will it need to be configured in any way? Many thanks. Ash Quote
GalaxyGuy Posted Monday at 12:05 Posted Monday at 12:05 Just ensure the address is set to an available slot (rotary dial on the keypad PCB) connect and enter / exit engineering to find the keypad. Use diagnostic menu 61.1.2 to view current keypad addresses. Normally setting the new keypad to rotary position 1 will be fine as an existing keypad will be at 0. Quote
ashs Posted 22 hours ago Author Posted 22 hours ago (edited) Thank you. Is it just connected in parallel with existing keypads? Is this one connecting via RF. Is that an option? Keypad RF?? If this is the case, I would I add it? I can easily add a power supply to it. Other than the engineer code, do I need to know anything else before connecting it? Edited 21 hours ago by ashs Quote
GalaxyGuy Posted 11 hours ago Posted 11 hours ago Yes, parallel connection on the rs485 bus. A to A and B to B. You don't get an RF keypad. You do get the SelfMon VMOD module, which gives a keypad via browser on your WiFI. Quote
