optima xm6
Guest jonnychips
Guest jonnychips
can anyone please help with a user guide for the optima xm6 in pdf format
would be most gratefull
cheers
jonchips@supanet.com
Guest kenny james
:D hi jonny,if you have no look in getting a pdf,let me know what you need to know about the xm6, i dont have details on pdf but can help you out if needed.
Johnny,
I have sent one to your e-mail address in pdf format.
Good Luck!
Steve
Steve Kendall
Plymstock Security Systems
  • 2 years later...
Guest ukchik33
Johnny,
Good Luck!
Steve
Hi I believe you have copy of optima xm6 user guide. Just moved in to new house but do not have previous owner's pin no can you help.
My e-mail address is lorraine.wylie47@ntlworld.com
Thanks
  • 5 months later...
Guest shellylady
Johnny,
Good Luck!
Steve
Hi Steve
My mum has just moved into a house with an optima xm6. she has no user guide.
i have figured out how to change the code for her it was the same way as my Melcom.
But at the moment she has to put in her code then press omit 6 then set when she wants tot go to bed. I have programmed my own house alarm with part guard zones so I just have to do my code and set ( and obviously the relevant zones are omitted auto).
I have been trying to figure out how to do a part guard for her because she is too old to remember the CODE-omit 6-set thing.#
Can you help?
Can you send me a user guide?
cheers michele.kay@ntlworld.com
Hi ,
There is a copy in the Gallery , although it wont show how to set-up a part guard , as the XM wont do this.
Regards.
Guest shellylady
Hi ,
Regards.
Thanks
I thought as much.
nevermind I'll see how she goes on and then maybe get someone to fit a new panel for her.
The house she moved from was great it was just a panel and she didnt have to put numbers in ( only when she got up or came in) she just had 2 buttons to press. she pressed the full button when going out or the part button when going to bed. dead easy.
Thing is I can't remember what the name of that panel was to ask for one of them to be fitted.
Ta anyway
However, under the new regulations single button setting is no longer permitted as this would allow an unauthorised person to aet the alarm.
Yep, much better to give your code out to all and sundry. :rolleyes:
Guest shellylady
What a great idea ****** If i give out her PIN to everyone she won't have to worry about the alarm going off when the burglars come in............. :P:D
