jmeader43 Posted yesterday at 20:51 Posted yesterday at 20:51 I have a couple of these driveway sensors that work fine and I’ve just had to cut all the wiring out to replace the old unbranded panel with a Texecom Premier Elite 24 The model of the driveway beams is Optex AX-100PLUS I would like to have the driveway sensors make a noise on the speaker next to the alarm panel like before I cut it all out I was unable to trace the wiring without cutting it out unfortunately There is a third party relay on a PCB which I have still got and I think it was wired to the driveway beams to convert the n/o to a n/c for the alarm panel to monitor I also have a new Shelly Plus 1 relay I could use if it achieved the outcome Quote
sixwheeledbeast Posted yesterday at 21:56 Posted yesterday at 21:56 |Doubt you need any relays. Just wire them into a zone, set as some unused/custom zone type and program as chime or 24hr whichever you want. Quote
al-yeti Posted 23 hours ago Posted 23 hours ago 2 hours ago, jmeader43 said: I have a couple of these driveway sensors that work fine and I’ve just had to cut all the wiring out to replace the old unbranded panel with a Texecom Premier Elite 24 The model of the driveway beams is Optex AX-100PLUS I would like to have the driveway sensors make a noise on the speaker next to the alarm panel like before I cut it all out I was unable to trace the wiring without cutting it out unfortunately There is a third party relay on a PCB which I have still got and I think it was wired to the driveway beams to convert the n/o to a n/c for the alarm panel to monitor I also have a new Shelly Plus 1 relay I could use if it achieved the outcome As above , why can't you just connect the existing relay output to a zone? Etc relays probably can be used to activate something else like a light perhaps Quote
jmeader43 Posted 16 hours ago Author Posted 16 hours ago 8 hours ago, sixwheeledbeast said: |Doubt you need any relays. Just wire them into a zone, set as some unused/custom zone type and program as chime or 24hr whichever you want. This sounds promising and I am wondering if the Premier Elite 24 panel can simply monitor the zone as a N/O circuit. I could also look at wiring the Alarm and Tamper on the Optex beam as EOL rather than Double Pole Quote
jmeader43 Posted 16 hours ago Author Posted 16 hours ago 6 hours ago, al-yeti said: As above , why can't you just connect the existing relay output to a zone? Etc relays probably can be used to activate something else like a light perhaps Yes I would prefer to wire the Optex beam directly into the Texecom Elite 24 zone so I am going to try this and see if it can monitor the zone as a N/O circuit. The Optex beam was wired Double Pole but I may be able to change it to EOL too Quote
MrHappy Posted 13 hours ago Posted 13 hours ago 3 hours ago, jmeader43 said: Yes I would prefer to wire the Optex beam directly into the Texecom Elite 24 zone so I am going to try this and see if it can monitor the zone as a N/O circuit. The Optex beam was wired Double Pole but I may be able to change it to EOL too post the facebook picture & some one will advise (saw you get slagged off Quote Mr Veritas God
jmeader43 Posted 13 hours ago Author Posted 13 hours ago 1 minute ago, MrHappy said: post the facebook picture & some one will advise (saw you get slagged off Thanks I think I have solved the issue. By wiring the beams as NO into the panel I can enable the Chime on a zone. I believe the third party relay was for a floodlight which is no longer there. I will upload the photos here as well Quote
sixwheeledbeast Posted 12 hours ago Posted 12 hours ago There is a normally closed output on the relay too.... Quote
jmeader43 Posted 11 hours ago Author Posted 11 hours ago 49 minutes ago, sixwheeledbeast said: There is a normally closed output on the relay too.... Yes you’re right, I may actually just swap the wire over and keep it as NC. Makes me wonder why it was set as NO but I can test both and see what happens 11 hours ago, al-yeti said: As above , why can't you just connect the existing relay output to a zone? Etc relays probably can be used to activate something else like a light perhaps Yes I would prefer to wire the Optex beam directly into the Texecom Elite 24 zone so I am going to try this and see if it can monitor the zone as a N/O circuit. The Optex beam was wired Double Pole but I may be able to change it to EOL too Quote
