Chris Teague Posted January 4, 2005 Posted January 4, 2005 Smarty (Old BT Buddy), or anyone for that matter. Anyone know where you can get the BT connector's 1A (Blue Bean's) or 8A's (Clear Crimp's) from? Grease filled not an issue. CPC do a version of the 8A's, but they are c&*p & fall apart as you take them out of the box They are great for making a joint in a PIR etc. Regards Chris Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
Monteey Posted January 4, 2005 Posted January 4, 2005 Yeah i wouldnt mind knowing as well Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest Posted January 4, 2005 Posted January 4, 2005 Try these at Mills Ltd, or LJD have some 3M ones. Can't see any of those falling apart. Just about to order some from Mills myself as the lot that I liberated from the nice BT man have depleted
Chris Teague Posted January 4, 2005 Author Posted January 4, 2005 Try these at Mills Ltd, or LJD have some 3M ones. Can't see any of those falling apart. Just about to order some from Mills myself as the lot that I liberated from the nice BT man have depleted That's the little beauties, thanks Lurch mate, most of my BT buddies have moved onto other things now, so supplies going low The Blue ones are good too, was looking around other sites, I think Egerton may have done them? Not sure though. Ta mate Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
breff Posted January 4, 2005 Posted January 4, 2005 I was going to suggest RS Components but I've just looked on their website and they're 4 times the price Looks like I'll get them from Mills in future. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Smart Electrics Posted January 4, 2005 Posted January 4, 2005 There is a design problem with those 3M orange crimps if using on 0.5 ali or 05-06 copper they cut into the cable to much leaving HR disses. Bathches from Feb to Sept seem to be the problem. Hopfuly 3M have delt with the problem now!!
Chris Teague Posted January 4, 2005 Author Posted January 4, 2005 Smarty, I've PM'd you mate Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
Lectrician Posted January 6, 2005 Posted January 6, 2005 http://www.telecomsupplyline.ltd.uk/catalogue/underg.htm Great company. also... http://www.austin-taylor.co.uk/ Email : martin@askthetrades.co.uk
Guest Posted January 12, 2005 Posted January 12, 2005 Try these at Mills Ltd, or LJD have some 3M ones. Can't see any of those falling apart. Just about to order some from Mills myself as the lot that I liberated from the nice BT man have depleted 36084[/snapback] :!: These are ment for solid core cables. Such what I use for alarm cabling here. These WILL cause you troubles later since they cut in the core so when using multicore cable this type connector will cut outer cores and doesn't actually connect. :!: *goes to search for good and cheap connectors for multi core cables*
