Posted (edited)
It's an HKC SW-1070 I installed at the end of 2019. I know, it's not a DIY alarm. During a recent power cut, it ran the system for 10 hours no problem The panel isn't complaining about any issues (maybe it doesn't do this, but there's a battery test in the engineering menu. I presume that does a load test).
Edited by Eugene's DIY Den
Clarifying something.
Hi,
The battery should be replaced every four years. This is the manufacturers expected lifetime guidelines. I have known batteries to continue to hold good life long after four years, but accredited installers have to follow the manufactures guidelines.
The performance of the battery is effected by many things, the quality of the electricity more spikes and fluctuations will reduce the life of the battery. The quality of the charging system (HKC is generally good) power cuts discharging and charging the battery will reduce its life.
The size of the battery should reflect the current pulled from the system.
Yuasa rate NP batteries as 5 year service life for use within alarm systems, other manufacturers maybe different.
From experience you could get 10 years from a Yuasa one but it's best to swap before it's deteriorating.
As above
But battery can sometimes prematurely die , might be example in a loft where I seen them die quicker , or sometimes boiler room and so on
Yes load test , try it
But you might be running all wireless aswell?
Every fire years in an intruder alarm
Every 4 years in a fire alarm
Unless they fail earlier...
  • Upvote 1
