Guest Posted January 5, 2005 Posted January 5, 2005 what you saying we dont understand each other ?no m8 i did get that perfect and thnaks 36218[/snapback] So you did, I see what you meant now! Think I need to go grab a drink!
Guest Mickie D Posted January 5, 2005 Posted January 5, 2005 right i have been searching but cant find what i want to know so heres another question i have installed them magnet door sensors is there another type that are fitted in the doors i have seen them before but cant remember what they are (where you drill into the door) and also whats the best sensors for windows ? and last but not least how many door or window sensors can be put on a zone as i would like to do one room per zone for the sensr contacts... is this ok ?
Monteey Posted January 5, 2005 Posted January 5, 2005 I think you mean flush door contacts, they're available from any alarm wholesaler, you drill a 20mm hole for them They should be fitted within 4 inches of the opening edge of the door/window Yes you can put more than one door contact/window on a zone but i always try not to Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest Posted January 5, 2005 Posted January 5, 2005 Again, as Monteey said! For windows I'd usually go for a Viper vibration sensor.
Guest Mickie D Posted January 5, 2005 Posted January 5, 2005 Again, as Monteey said!For windows I'd usually go for a Viper vibration sensor. 36227[/snapback] sounds good are these the ones ? http://www.letsautomate.com/11026.cfm and how are they mounted the picture does not tell the right story and if my galaxy is old as everyone is telling me will these new devices work with it ? thanks very much for the patients and answers you guys have Mickie
Guest Posted January 5, 2005 Posted January 5, 2005 They're the ones! They'll work fine with your Galaxy. The wiring is the same as the new versions, it's only the ROMs that are different. As for mounting them, I usually fit them on the frame, just above the handle. AFAIK, most people do.
Guest Mickie D Posted January 5, 2005 Posted January 5, 2005 They're the ones!They'll work fine with your Galaxy. The wiring is the same as the new versions, it's only the ROMs that are different. As for mounting them, I usually fit them on the frame, just above the handle. AFAIK, most people do. 36230[/snapback] what about on sash windows ? and also i have two windows in my sons room that open from the top inwards and stop at a certain point im gonna have to take some photos lol
Guest Posted January 5, 2005 Posted January 5, 2005 Can't you just put normal windows in? You need to put them somewhere rigid, near to a likely point of someone ramming a crowbar in, basically. You can alter the sensitivity of the Vipers so you don't have to have them attached a specific distance away from the frame edge.
ian.cant Posted January 6, 2005 Posted January 6, 2005 I can supply a 500mtr drum of white belden, for the right price of course.
