jmeader43 Posted February 18 Posted February 18 I have 2 of these run in series and the customer is saying they are too loud They are connected to a Texecom Premier Elite 24 and being used with the Chime facility Is it possible to dial down the volume by wiring in something that’s adjustable so they can fiddle with it themselves and then I don’t have to keep adjusting it myself The product is this one: https://connectec.uk/security/intruder-alarms/wired-alarm-systems/wired-alarm-sounders-and-bells/8-ohm-alarm-extension-speaker-with-tamper Quote
jmeader43 Posted February 18 Author Posted February 18 Or how how simply muffling the speaker with some foam as they just suggested ? Quote
sixwheeledbeast Posted February 18 Posted February 18 Premiers have separate programmable volumes for chime and advisory tones 1 Quote
AlarmsGalore Posted March 10 Posted March 10 (edited) As above reply said, the premiers do have the changeable tones. You can do it by: Engineer Code -> Global Options -> System Options Edit: Sadly the cxt would have to ask you as it's only accessible via eng menu. Thanks Edited March 10 by AlarmsGalore Quote
sixwheeledbeast Posted March 11 Posted March 11 There is some volume adjustment in the Master User menu but it's less flexible than the engineers options. Quote
