Bunster Posted 14 hours ago Posted 14 hours ago I have a very old intruder alarm which uses an autodialler to contact ADT for monitoring. I am about to be switched to Digital Voice by BT. I understand that I can use an ATA so that the alarm can still contact ADT via Digital Voice. What ATA would be best for this? Thanks! Quote
sixwheeledbeast Posted 14 hours ago Posted 14 hours ago You could try but there is no guarantee it will work properly. You will also have the issue that a power cut will disable the alarm signalling. Best option is to upgrade the system/signalling to a more modern digital compatible one. Quote
norman Posted 13 hours ago Posted 13 hours ago If its still under contract speak to them and let them sort it out. Quote Nothing is foolproof to a sufficiently talented fool.
MrHappy Posted 8 hours ago Posted 8 hours ago 6 hours ago, Bunster said: What ATA would be best for this? none are likely to work correctly when needed, you either need a digiair as signalling up grade, of replace the controls to one which uses an app Quote Mr Veritas God
PeterJames Posted 7 hours ago Posted 7 hours ago 5 hours ago, norman said: If its still under contract speak to them and let them sort it out. QFA they will charge to sort it out, but like most good companies they will have a solution Quote
