thanks ill try that in the morning and post my results
many thanks for taking the time to help and all others that posted
if it transpires that i need to have all 8 connected how can i short out the contacts as suggested before bearing in mind i only have 3 cables on each plug red/black and white?
I ask as only 1 pir is required to cover the house in question
many thanks
Posted (edited)
Can you scan and send one of us a copy of the manual? This would help enormously.
36163[/snapback]
no probs at all ill do that aswell in the morn how do i post it on here though?
just spotted youre e-mail on bottom of last reply should i just send direct to that?
Edited by spencetate
Posted (edited)
Yes, feel free to send it to me or anyone else who has replied. I think that would be better, I/we will then post it in the trade section.
Edited by Brian c
If you don't know......ask.
im a sparkie would that qualify me to join the trade section?
I ask as i am being asked frequently to do varuious alarm related jobs snd could do with all/any extra info i can get my hands on
and if so how would i go about joining?
Posted (edited)
You will need to fill in an application form and meet the criteria set out here.
Edited by Brian c
many many thanks to all who helped me out with this one
the alarm is now working properly(as much as it can for this model!!!)
I indeed had to link out the unused zones as follows:-
red=+ve
black=-ve
white=switch
switch was held to negative under normal so linked white to black on all unused zones
many many thanks again to one and all
spence tate
(and his happy dad :P )
  • 10 months later...
Guest alanbit
Am having a problem with this unit as well. Only came with 4 pir but need to add 4 more! Cant' find any info about the pir's and not havn't been able to get my existing (from a previous system) 6 cable pirs to work
Any idea on:-
where to buy more suitable pir's
or how to wire up the 6 cable pirs to work (2 power, 2 24hr , 2 n/c switch)
cheers
Alan
I think the 3 wire alarms work by using a NC loop powered from the -ve on the PIR itself so a link from -ve to one of the zone terminals and then a link from the other zone terminal to the -ve return on the panel should work.
Not sure if tamper is something these panels can cope with! Personally, I'd just bin it. ;)
