al-yeti Posted Thursday at 14:05 Posted Thursday at 14:05 How would you put a maglock here ?as standard lock keeps failing as it's being forced open over time Quote
norman Posted Thursday at 15:47 Posted Thursday at 15:47 Insecure side, double sided 3m, next! Quote Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted Thursday at 16:02 Author Posted Thursday at 16:02 14 minutes ago, norman said: Insecure side, double sided 3m, next! Insecure side ? So how will it be protected? Quote
norman Posted Thursday at 18:15 Posted Thursday at 18:15 Assumed you would be OK with that and sticky tape Quote Nothing is foolproof to a sufficiently talented fool.
PeterJames Posted Thursday at 20:49 Posted Thursday at 20:49 You could maybe fit a morticed shear mag, or a shoot bolt. But I would probably go with Steves idea and fit an external mag on the outside and use star screws or anti tamper screw heads to prevent someone unscrewing it or a architectural mag https://www.cdvi.co.uk/products/categories/magnetic-architectural-handles/ Quote
al-yeti Posted Thursday at 22:53 Author Posted Thursday at 22:53 4 hours ago, norman said: Assumed you would be OK with that and sticky tape Brown tape yes 1 Quote
PeterJames Posted 20 hours ago Posted 20 hours ago 12 hours ago, al-yeti said: Brown tape yes Im glad you didnt call it tape of colour Quote
al-yeti Posted 10 hours ago Author Posted 10 hours ago 9 hours ago, PeterJames said: Im glad you didnt call it tape of colour Cmon man , I am with the supreme court in this one Quote
MrHappy Posted 9 hours ago Posted 9 hours ago (edited) rim releases normally fall to bit by the machine screws falling out thread lock helps its either the door slamming or cnuts braying the door... a shear lock is very dear ! Edited 9 hours ago by MrHappy Quote Mr Veritas God
al-yeti Posted 7 hours ago Author Posted 7 hours ago 2 hours ago, MrHappy said: rim releases normally fall to bit by the machine screws falling out thread lock helps its either the door slamming or cnuts braying the door... a shear lock is very dear ! Shear lock seems the way, although I never done one of those, don't seem to difficult, just need to get some tape to fix it on Guy in this building doesn't mind spending Any examples of shears on how your fitting them ? Quote
