Eugene's DIY Den Posted Thursday at 16:04 Posted Thursday at 16:04 (edited) The sounder on my alarm sounds "scratchy" and the volume is increasing and decreasing a bit as though there's a loose connection. Or maybe a failing battery is the problem? Is this the battery that goes into these sounders? My electrical wholesaler says that the battery is nearly as expensive as a new sounder, so maybe it's better to buy a new one if e.g. corrosion on the PCB board is what's causing the sound problem. https://www.hkcsecurity.com/ie/en/products/auxiliary-equipment-wireless/extended-6v-battery-pack-rf-sabb Edited Thursday at 16:05 by Eugene's DIY Den typo Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
al-yeti Posted Thursday at 16:50 Posted Thursday at 16:50 43 minutes ago, Eugene's DIY Den said: The sounder on my alarm sounds "scratchy" and the volume is increasing and decreasing a bit as though there's a loose connection. Or maybe a failing battery is the problem? Is this the battery that goes into these sounders? My electrical wholesaler says that the battery is nearly as expensive as a new sounder, so maybe it's better to buy a new one if e.g. corrosion on the PCB board is what's causing the sound problem. https://www.hkcsecurity.com/ie/en/products/auxiliary-equipment-wireless/extended-6v-battery-pack-rf-sabb Although wholesaler is talking **** about the battery pack Just replace the cr123 see if it helps you don't need the whole new pack open it 6xbatts Maybe the sounder itself is weather damaged? The sounder yes is expensive ish Quote
Eugene's DIY Den Posted Thursday at 17:14 Author Posted Thursday at 17:14 (edited) 24 minutes ago, al-yeti said: Although wholesaler is talking **** about the battery pack Just replace the cr123 see if it helps you don't need the whole new pack open it 6xbatts Maybe the sounder itself is weather damaged? The sounder yes is expensive ish Are they rechargeable C123s? This is a wired sounder. I'm going to open the sounder to see what the story is. My old sounder failed due to corrosion, but that was because it had a high voltage strobe and voltage tracked across the PCB due to the varnish breaking down and moisture presumably. A new sounder is €47 + VAT. Battery he says is €38 + VAT. Edited Thursday at 17:15 by Eugene's DIY Den Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
al-yeti Posted Thursday at 17:25 Posted Thursday at 17:25 10 minutes ago, Eugene's DIY Den said: Are they rechargeable C123s? This is a wired sounder. I'm going to open the sounder to see what the story is. My old sounder failed due to corrosion, but that was because it had a high voltage strobe and voltage tracked across the PCB due to the varnish breaking down and moisture presumably. A new sounder is €47 + VAT. Battery he says is €38 + VAT. Oh in that case it's just a few quid dude for the internal backup battery Thing is in your first post you have a link for RF battery pack hence I thought it's RF sabb But the RF sabb can also run off the panel on 12v but the signalling is via the RF Wired bell, then you can get any bell as a replacement if you had to Quote
Eugene's DIY Den Posted Thursday at 17:30 Author Posted Thursday at 17:30 (edited) 6 minutes ago, al-yeti said: Oh in that case it's just a few quid dude for the internal backup battery Found the instruction leaflet. It's a 6V, 170 mAh, NiMh. Are they standard, off the shelf battery packs or special HKC ones? Also does the sounder battery power the sounder, with the cable intact and the sounder getting power, or is it powered by the panel? I'm trying to establish whether a bad battery in the sounder is causing low voltage or pulling down its charging voltage. I'll put a meter on it to see what the story is. Edited Thursday at 17:34 by Eugene's DIY Den Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
Eugene's DIY Den Posted 17 hours ago Author Posted 17 hours ago (edited) I could use something like this maybe, depending on dimensions. The existing battery has a capacity of 170 mAh, trickle charged at 14 mA. https://www.amazon.co.uk/6V-330mAH-Ni-MH-Battery-Replacement/dp/B09C2FVP9L Edited 17 hours ago by Eugene's DIY Den Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
james.wilson Posted 14 hours ago Posted 14 hours ago I doubt it's the battery As in causing your sounder issue Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
