Cieska Posted 18 hours ago Posted 18 hours ago Hey, Need to think of the wiring logic for the automatic opening mechanism door with a maglock to be released in a fire event from the Gallagher panel. A few spare puzzle pieces are available in my brain: I want to avoid using additional relays and hanging on the cables in an already tiny panel. Usually, the door opening mechanism is controlled with 24v and recommended to be controlled with dry contacts, but would I be able to use a common ground in some way? Gallagher fire interface relay / DC distributor has some other ways to be wired in, I wonder if this can be employed to achieve this function? I may sacrifice additional Gallagher controller output for this, but I couldn't find a function for this, or is it a logic block's function? Happy Easter. Quote
