Texecom Ipaq Plus
Guest rafal
Hi all
Just installed 10 Impaq Plus sensors. The sensitivity pot
Is adjusted to roughly same setting /let say 10 o
Swap one of the 'good' ones with one of the other two. If the problem (I assume you mean they won't pick up as well as the others) is still there, then it is due to the location of that sensor. If the problems goes away, it suggest faulty equipment.
If you don't know......ask.
36249[/snapback]
Thanks, that confirms my suspicions
what are you using for the "bang" test?
36299[/snapback]
A pointy screwdriver handle
Ah, the choice of professionals.
36301[/snapback]
One picks up things here as one reads
I usually use my mobile phone.....................................
That reminds me, whats Carphone Warehouse Repair Centre number again?
