Accenta 6
Guest Murph
Can anyone give me some advice on an Accenta 6
We were called out to a customer who has one of these,
Installer ceased trading or just not answering his phone.
Tamper led on the rkp is lit .panel is blank end .
No audilbe response from keypad presses, I would have expected to hear some beeps.
System is still powered up. so I want to crash it and then check it through.
Trouble is I don't know who the makers are, as I am going to need an engineer manual.
or at least default engineer code
Also will probably need to source a user guide as the householder has lost theirs.
Does anyone know the website for the manufacturers?
By choice I would swap out the panel for a scantronic or gardtec, but it looks bad when your asked to see if you can fix it, to just turn up and say it needs replacing, so I thought I would have a go.
This is not a current product and is aimed at the DIY market.
36343[/snapback]
It's meant to do that. Clear the tamper fault then it will come back to life.
Thanks for the response guys.
almost awesome, three replies overnight.
Think I will swap out for a panel we understand.
Simply on the grounds of economics, by the time the customer has paid the time for an engineer to play about with the accenta , it would be better to install a new panel.
The last ADE product we had anything to do with was a logic 4, so thats giving the age away!
Thanks again.
Murph
Well you could try powering it down and then back up again and fit a new battery, if the customer insists on a repair.
But you would be doing them a favour to rip it out and fit a decent one, as the accenta is technically poo.
