Programming flowchart for FAI Security Guard II
Guest bikaron
Guest bikaron
Hi,
The battery in my FAI Security Guard II died some time back. I've replaced it but the unit has lost it's settings and wont recognise the two external sensors. Could someone please provide a link to where I can download the programming flowchart. I already have the user manual which as you know is of no help.
I've read through a heap of other posts on the same topic but didn't find any links to where I could get a copy.
Thanks.
Hi,
Thanks.
36679[/snapback]
If you search for your panel on the site this panel has been covered many times, think the member that can help is elbert or egbert?
The info is out there if you search :)
  • 11 months later...
I have the same problem but cannot find a solution anywhere????
Thanks in advance,
Trent
Thanks in advance,
Trent
Read the replys above and the solution will become apparent.
Maybe I'm not the greatest with computers but I cannot find the solution anywhere
