adt technistore seed code
Guest andy jinks
Guest andy jinks
can anyone tell me the seed code used by //.National Installer.// in the galaxys.
i cant be botherd to crash it yet.
Guest andy jinks
Thanks m8 .....does anyone know if they use differant seeds for other areas.....
need peterborough....
Ive set up a few in Staffordshire with the 002 seed code as well.
Guest andy jinks
thank you all....
i think AIM use 002 seed so i will give them a call..
by the way the system i need to reset used to be one of them //.National Installer.// pound a day jobs that somone asked me to look at(they didnt want to pay any more).
can anyone tell me if //.National Installer.// are able to burn the engineer code into the panel so if you havent got the code you cant default it.
Guest andy jinks
i dont know what its called m8.
its 1 of them 1s with the built in digi and the red and green buttons on the k pad and 8 zones i think.standard k pad shape .
i got a 002 code 4 it but it didnt work.
The //.National Installer.// dealer Galaxy panel's came with red, green and blue keys on 2,5 and 8. They're used as hotkeys for fire, police and usually medical emergency's.
Just thought i`d add to the confusion.
A File I`ve been handed states that PRIOR to November 1999:
ADT used:
1032 for Scantronic reset
4 for Technistore reset
4 for Karizma reset
4 for Menvier reset
Modern Alarms used:
2000 for Scantronic reset
2 for Technistore reset
10 for Karisma reset
10 for Menvier reset
Thorn used:
1475 for Scantronic reset
80 for Technistore reset
8 for Menvier reset.
Guest andy jinks
looks like i will have to go and get me tools out (big bit of wood)
  • 1 month later...
Guest Neil Jones
Thought all //.National Installer.// galaxy panel with on board digi's model ended in "plus" they put a sneaky solder link across where the blue reset link used to be. Could try removing, depends on how brave your feeling!
